Throttle cable compatibility?
West Michigan area
Wondering if a throttle cable from an older carbed Vector Mountain would work on a newer (2014) efi Vector LTX? A bud is putting a mountain riser on his and we don't want any surprises! If not, who has had the standard cable lengthened?
Thanks in advance for the help.....
measure it, for all you know someone couldve replaced it with a tractor cable instead of a factory, as long as the in/out travel is the same and you have enough free play in the cable then you should be fine
MOTION PRO will custom make you a cable any length you want, usually only for a small amount ore money than a stock cable.
