BlkNytro
Not sure where the other topics are on this but I need to find out where to find a longer throttle cable for an RX-1. I lifted the bars 4 inches. Which cable will work and how do you take the stock one out? Thanks.
mbarclay
i put on a 4 inch riser on my warrior and i needed these parts from a 2005 RX1 Mountain
8FW-26311-00-00 Throttle cable
8FW-26330-00-00 Choke cable
8FW-25872-00-00 Brake line
8FK-26351-00-00 Parking Brake Cable
BlkNytro
Oh I didn't realize that I needed the other cables. I have everything hooked up. It only seemed that Ithe throttle needed to be replaced..thanks!
04rxw10
- Jan 28, 2008
- Lisbon Falls Maine
- androscogginubm.org
you dont need to replace all of them.
I replaced all of mine because I did a 7" riser
mbarclay
hmm....thats weird with my 4" i defiently needed to change all of the except the chocke but it was a little tight so i changed it anyways. the parking brake cable was wicked tight even without turning the bars......but hey if yours arent tight that will save ya some $$
BlkNytro
Intresting..for what is worth the riser I'm using is a pivot riser, not sure what you are using but with the riser shifted forward it puts less pull on the wires..
mbarclay
that could be the reason mine is just a block riser
i put all of those cables and brake line on mine as my rox extenable riser is pivoted back instead of ahead like most are. still have to extend the wireing before i can extend it at all though.
