TRiGGeR605
Hey guys, I have a 2013 Nytro and added the OFT relocator awhile ago. I think during install I must have stretched the throttle cable to much and down by the last connection where the rubber meets the "L" metal piece. This weekend my Nytro would suddenly take off for a split second as if the throttle was wide open before the TORS would kick in. In the spot mentioned above the rubber part was pulled out of the crimped metal "L" causing the cable to bind up.
I am in the process of replace the entire cable. I'd kind of like to get a longer cable in case down the road I wanted to get risers. I'm wondering how much longer is the MTX cable compared to the XTX and if it would work as a replacement? Or, any aftermarket parts.
I believe the XTX, RTX and base model all share the same throttle cable, the MTX cable is 1.5" longer
TRiGGeR605
But the MTX is plug and play?
moab11
- Feb 4, 2010
- Thunder Bay, Ontario
- 2016 SKS 155
yep, I switched my throttle and brake line this summer for the MTX ones so I could run a riser on my XTX. Both bolted in just like stock, except for being longer. Wish I would have done it sooner.
