stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
i know nothing about the timbersled units, i am curious but do all the kits use the same arms and just use different install kits/rails??? any info would be appreciated.......thanks
bholmlate
each kit is specifically made to fit each different chassis. They all have slightly different mounting points on the chassis. The TS Suspension doesnt attach to the Stock OEM rails in the same location so you need a fit kit whcih is nothing more then bolt on mounting bracket that you secure the the OEM rails which allow you to bolt on the new suspension kit. The arms look the same but they are all slightly different. The rails you buy from Allen were design to work with the mountain tamer kit making it much easier to install the suspension kit. The kit themselves are not interchangable however.
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
thanks for the info.
