dmaxx
- Apr 5, 2006
- sw Michigan
- 2014 Apex XTX, 2012 Apex SE, 2000 Vmax 700, 2000 AC Z-370, fast
- White Pigeon, MI
where do you guys ride? I ran 108 (same as 96 on a shorty) on both my attaks and LTX with none bent. Are you running cheap studs?? I run either gold diggers or mega bites.
Same here. We run the same on our stock Warrior, never a problem. I run 144 on my modded 03 as it needs it. Not all riders require 144-168. 96 is ok for the average rider and they should not bend or twist if you do not ride it aggressively and it will provide safety in the corners and on ice.
sconnierider
Again, it comes down to how you ride and what you weight. Physics. Weight divided by points of contact. Less torque over more contact points equates to fewer bent studs. Those flyweights can usually get away with fewer. Me, with hard pack, at 230 lbs. I need more points of contact!
