top idler wheel for Expert X?
tonykof
Williams MN
Looking for at least one, maybe both top idler wheels (the small ones on the top that go on the same shaft that the top of the shocks hook to)
Would like to source them from the us...mn if possible..?
Thanks Tony
I'm not sure what WPS stands for? If it's western powersports it looks like it is no longer available...?
I did get the original Bovin part #
RO100C-1001A
it's a 100mm wheel (3.936") & they are the same as the small ones on the btm of the slide..
I am getting a quote from 2M Motorsports in Quebec
Anyone know what the Bearing inside dia. is? I'm only about 40 miles from Wahl Bros & about 80 from Hi-Performace engineering...
thanks tk
No one seems to have 3.936" but if 4 1/4 or 4 5/8" would work that is a possibility...
Like I said, I tired to source the oem expert wheel for a month and couldn't so I got the 4 5/8" wheels. I ran them all last year without any problems.
I ended up just ordering a couple from the factory...I wanted to get something coming my way & it was going to be a couple days before I would have time to drop the suspension out to measure the shaft dia...thanks for your help.
tk
