yamahajunkie
anyone know the spec for the bolt that holds the primary clutch on?
thanks in advance!
thanks in advance!
yamahajunkie
anyone got their manual next to them?
LazyBastard
The manual quotes 110 ft#, but if you crank it to that you will break the bolt. I think the revised spec is about 85, then loosen, then tighten to 45 and leave it.
yamahajunkie
thanks alot LB your the man!! messed with the weights and i remembered hearing something about that. couldnt find the numbers though. a broken bolt there would suck to riding in the morning. thanks for the help.
junkie
junkieSimilar threads
