Torque specs for primary and secondary?
ZR800EFI
Morewood, Ontario
Can someone please give me the torque specs for the Apex? Just in case it's not in the manual when I get home...
Thanks!
not sure,but i can tell you the primary bolt is MUCH MORE STOUT then a DOO primary bolt,which have been breaking upon 89ft lbs....
SO IMO you can easily put 75-80 ft lbs without any worries...I alway recommend ANTI SEIZE for bolt threads where they go into crank.
Dan
Primary.....1st Set at 112 FT LBS........loosen reset to 43 FT LBS.
Primary cover 6 bolts 10 FT LBS EACH
Secondary......46 FT LBS / Helix nuts 17 FT LBS.
WRONG THE PRIMARY TORQUE IS 80-85, NOT 112. this is a missprint in the manual and could break the bolt.
torque it first to 85, then back it off and re-torque it to 42. Thats the primary clutch bolt. :Rockon:
Yep you were ABSOLUTELY CORRECT
85ft lbs 1st then 43 ft lbs :oops:
There are a wack of 04/05/06's Running around that I did TOO TIGHT I guess, THANKS FOR THE TIP. ...........That #$%&* Embarassing to have done that...........OOOPS :oops:
Funnny I took Mine off today and check everything looks perfectly ok.......Phew ;)!
