Yeller
Was running down a nice section of trail yesterday for about 5 kms at a steady throttle doing 80-90 km/hr when all of a sudden the engine started cutting out and the engine light came on with the 84 code. It back fired once or twice so I shut it off and re-started it and it ran fine. No more problems the rest of the day. Any idea why this would happen?
nealchick
- Jan 14, 2009
- Long Island, NY
- www.briarclifflandscape.com
Not sure if it's the same in the Nytro, but I had that problem and took it in, they replaced the ignitor as a warranty item and cured it. I have an 05 vector. That's def the TORS notification. Others have said to check the throttle cable for proper function, might be all you need. Or you can disconnect TORS, search here someone gave a step by step to wire it to itself.
N---
N---
