Lightbrew
- Jan 29, 2007
Track damaged on 06 Apex need to change. Does anybody have the torque specs on gear and chaincase cover bolts?
ROCKRTX
The big 36 mm top gear nut is 65 ft/lb,the bottom gear is 35 ft/lb ( manual said to put loctite on bottom bolt ) and the cover is 17 ft/lb.
Little bolt outside the cover that hold reverse gear shaft is 7.5 ft/lb with loctite.
