srxpotts
Will be cutting and fully clipping 136 ripsaw how may and what kind will i need guides and clips
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Just finished replacing all the clips on my 05 Warrior, 136" ripsaw. Required 34 clips without the extra holes. With cutting I think you will need 68 clips in total. I purchased my clips at www.royaldistributing.com ( page 163 - 2010 catalogue). You will need the "L" clips for 1" wide window and 1.75" long. I used the " ATS Track Clip Tool" vice/press type tool you can use from the outside of the track. I think the plier-type track clip tool you need to remove your track and install from the inside. The vice/press tool worked very well with an air ratchet and finished tightening a few turns with a regular socket.
thrasher
- Nov 22, 2006
- 06 Vector RS ER
Sorry, used 36 track clips, so you would need 72 for fully clipped track.
srxpotts
thanks for the info!
