Track Edge Damage
twyztid
Middleville, MI
2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
LOCATION
Middleville, MI
The track on the sled that I am repairing (from my other thread) has a spot with edge damage that probably was caused by the same accident. Is this usable or junk? The track looks good otherwise and has just under 2600 miles on it. The damage is on the back side of the lug but you can see the end of the fiberglass rod.
i ran one that looked worse than that all last season on a phazer and another one on my rx a few years ago with no problems. it will probably be fine. it will shed that lug at some point but should still make the season.
With no studs on the outside I think you will,be OK. I would run it, just keep an eye on it.
I work a tire company that has their own retread plant. I have the capability of cleaning up the damaged area, putting in some new, uncured rubber, and curing it in our curing chamber. It gets to 250 degrees. The track & studs would be fine but I am not sure if the nylon part of the lock nuts on the studs will handle 250 degrees for 1.5 hours.
Sent from my SM-G930V using Tapatalk
It only has 108 (I think) down the middle right now.
I'll pull the track off now and replace it if it may only last a season. A friend may be buying the sled from me and won't want any issues. Plus the track may need to come out to replace the left side of the tunnel.
i replaced both those tracks for the next season as it happened on both of them during the season.
that track probably would be fine on a lower horsepower sled.
if you are need i have a rip saw 136 used , but you can try shoe goo to repair that track we have had good luck with that stuff you can get it at wal-mart.
Is the track studded? Pics?
no stud i pulled off to put a corbra on.
Can you PM me details like miles on it and price you are looking to get for it? I will give you my email address then so you can send me some pics.
hi i have the track at the dealership i purchased sled from so i dont have picutures so send me and email an i will see if i can get them to take picture fore you but i would like to get $275.00 for it my it has on it 800 miles my email is jerrydarvell@yahoo.com
I will send you an email shortly.
