aksteepndeep
I'm looking to put a new track under the sled and have only found the 151" 2.3 lug. Has anyone actually fit a 15" wide or cut down a track and fit it under there? I was hoping for a 156ish lenght. Any help?
aksteepndeep
Anyone get a Firecat track? Anyone use a handheld hot knife with any luck??
rideblue
- Mar 17, 2005
- Buena Vista Colorado
- www.mountaintechbv.com
14.5" is the widest the track can be to fit in the phazer. Anything wider will not fit in the front of the tunnel. Some guys have cut a 15" wide track down on a table saw with the help of a friend or two. 151" - 159" 15" wide track are more common and way cheaper than the camo extreme.
aksteepndeep
RideBlue,
What lenght have you heard of for the sleds with boost? I'de like 153" if it will get the job done. The table saw option sounds "EXCITING"!!
HYFLYR
Get ahold of alpine motorsports in canada, they have done a few and they looked sweet.
aksteepndeep
I think I'll try to cut an old track and see how that goes. Maybe a grinder would work(kinda messy though).
Is the Attack 20 junk? Lots of them cheap
rideblue
- Mar 17, 2005
aksteepndeep said:RideBlue,
I ran a 151 on mine and we also have a few with 162's and 159's. I would stay with a 2.52" pitch 159 track becuase of the cost. We had to push the skids back when using 7 tooth 3" extrovert drivers on 162's because they were hitting the rail tips. Even with boost, I think they do not need the extra bit that the 3" pitch tracks offer. Attack 20's are cheap, but don't waist your time or money on them. They suck!
MT RX1 Mountain Man
phazer mods
rideblue do you have any pics you could post of your track setup for us? I think the wife's Phazer maybe going down the road in favor of an RMK 600 but in case that doesn't pan out I am going to have to do something to this sled to make it work in these snow conditions here. If I could figure out a way to get a 15 wide track to fit I would be more enthusiastic about doing other mods to it (Supercharger)
aksteepndeep
Table saw was not that bad with 3 guys. Not sure 2 would have been as easy. Took about 15 minutes and we went easy. thanks guys
- 10K
