JDKRXW
Will a 1 3/4" lug track fit in a Warrior using stock drivers?
Is anyone using one??
LazyBastard
Correct me if I'm wrong, but there should be 1" tunnel protectors in around the driveshaft, in which case you just remove them to gain the clearance needed.
JDKRXW
LazyBastard said:Correct me if I'm wrong, but there should be 1" tunnel protectors in around the driveshaft, in which case you just remove them to gain the clearance needed.
That's a very good observation, and I'd like to correct you if you were wrong ...but I can't, because my sled is at my cabin (very close to Sled Dog's home town).
Anybody else??
Jack_Shaft
I installed a 1.5" lug track last night on my 03 RX-1 and there is not enough space to install a 1.75" track in there without removing a portion of the - if not the entire - tunnel protectors.
