4strknytro
Anyone have a easier measurement than the weight deal to get me in the ball park for track tension. Can you just pull down as hard as you can and give me a measurement? This can't be rocket science. Just installed new sliders.
Ricketts
- Feb 29, 2008
- 2007 PhazerFX
I've always just set the track tension just tight enough that it doesn't ratchet on the drive wheels in deep snow. Too tight equals friction.
Good luck,
Rick
Good luck,
Rick
xt_gt
book says 22lbs. down & should measure 1.18"-1.38".
push down firm & check length if you don't have a scale.
Boo Rad
xt_gt said:book says 22lbs. down & should measure 1.18"-1.38".
Ahhh, the old "close enough" measurment system!
I use the ratcheting method.Set it loose.If it ratchets off a small jump go a little tighter.Probably saves hyfax a bit this way also.
4strknytro
Thanks for the tips guys. I just did not want to make any adjustments out on the trail the first ride of the year if it was to loose.
