tracks USA 128"
trailmarker
Toronto, Ontario
If I put a tracks USA 128' rail extension on my sled, will the studs on the added length track hit my rear tunnel cooler ?
does anone have 128' and a tunnel cooler ? do the studs hit it ?
I don't have the setup your talking about but can tell you that without the cooler you would have probably been fine, which is what they will tell you. However with the cooler I would say you will likely need something, be it protectors or tunnel extension. My guess is that if you look now you may see mark or two.
