Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
I want to try a 20 tooth sprocket on my FX and have a spare 18 tooth I know someone could use.
Correction, originally post a 17 tooth but it's an 18.
scottshewchuk
- Dec 29, 2013
I don't have a 20T for you but I wanted to try a 17T on mine.
Ruggybuggy
- Sep 1, 2013
What are you using on your sled?
nobrakes
Let me ask this.... is the number of teeth stamped on the side of the gear or is it a must to actually count the teeth.
If its stamped, then I'm running a 20 and was thinking about trying a 19 but haven't placed an order yet.
I recently put on a new freeride and added an Excell can. Im pulling 11,600-11,900 on the r's with that 20 and 85-87 on the dreamo'meter.
I havent touched the clutches yet... cant get ahold of Ulmer, but from what Im reading, the lower gear works better. Thats why I was considering a change. If I can get some input, I'll have a 20 for you.
Ruggybuggy
- Sep 1, 2013
I have an extra gear and want to experiment with a 20 to see if I can bring the sled up to 90mph. I'll check my gear and see if it's stamped on it.
Ruggybuggy
- Sep 1, 2013
Yes gear is stamped with the number so you don't have to count. My FX is running 18 and 41.
