Run quality fuel. You might want to run lower compression pistons or extra head gasket for safety. I did both. With a front mount turbo be prepared for an annual cracked header or exhaust leak . Other then that ; every one will want to ride it & after a few runs for curiosity no one will want to race you any more. I run 10 pounds boost with 10:1 pistons & extra head gasket & I have a big safety margin on 91 octane. At that boost they are silly fast for a trail sled. I gutted my exhaust & it is only slightly louder then stock until you open it up then it sounds like a formula 1 indy race car! You don,t even know the turbo is there until you open it up & on warmer days you can feel some heat on your right leg. I don,t have a rear heat exchanger & have never had an over heat condition even after multiple 1000' WOT runs.
