Iceman57
How sensitive is the transfer rod adjustment? I HAD mine set between minimum and half and I just changed the setting to just over half. When I first got my sled I adjusted it for less transfer to help eliminate some of my inside ski lift and it seemed to have worked. Today I added a 12mm sway bar to help with the ski lift and added some transfer back. I was just wondering if I will notice a difference.
06apexrtx
i put mine half way between the min and 1/2 as well for the same reason and noticed a big diifernce in talking off and handling from star(not corning) and like it so far. next step if i do it will be to put a 12 or 13mm bar my self.
Iceman57
TTT
LJ 452
Bring your binoculars, cause if it hooks, you’ll be watching birds when you hit the throttle. It seemed I could only run mid transfer after I stiffened the heck out of my skid; otherwise it would just pull the skis and want to flip. Some like that I guess, me I like to keep the skis on the snow, as they seem to work better there.
Iceman57 said:How sensitive is the transfer rod adjustment? I HAD mine set between minimum and half and I just changed the setting to just over half. When I first got my sled I adjusted it for less transfer to help eliminate some of my inside ski lift and it seemed to have worked. Today I added a 12mm sway bar to help with the ski lift and added some transfer back. I was just wondering if I will notice a difference.
I can definitley feel the difference on mine with just 2 turns of the nut. 4 turns goes from skis planted to almost out of control in the corners. I played with the limiter strap till I got close and then fine tuned with the transfer rod.
