trottle position sensor on a 04 warrior
NORWAY
does anybody of you now an easy way to adjust the tps with the voltmeter and how much volt shuld it have.
Why are you adjusting the TPS? If you can not find specs, check voltage on known good sled, if I see you did not have luck, I will check mine at idle, which could be slightly off due to idle adjustment. You should have an RPM & TPS voltage to be more accurate. If it is like autos, three wire sensor, one a ground, one a 5 volt reference line, & usually the center wire the TPS signal, the TPS signal is the only varying voltage on sensor if you operate throttle while checking. Never looked at it but TPS should have adjustment where it mounts to carb, just loosen & turn slightly.
i have adjust it to 0.7 volt. mesured beetwen yellow and black. it seems like the little rubber ring behind the tps was causing the tps to bend. it seems to work now. it was a strange fault,spessially because nowone have toushed it.
