Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Does anyone have the Yamaha trunk bag installed on the Apex XTX ?
I have a 2015 model , and the picture on the Yamaha Canadian website only shows it on a short track version , which is hooked to the bumper at the back.
On the XTX it appears the straps will be right where the exhaust is ,and could be a heat issue .
I didn't see this bag on the U.S. site .
An installed picture would be great , even better if it is on a sled with the WRP hi rise seat .
Any help is appreciated .
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
I have the saddle bags hooked up,
http://www.yamaha-motor.ca/pna/deta...oup=SM&unitYear=2012&items_per_page=12&page=1
but the trunk bag hooks the same with the same hardware. Buddy of mine has it.
here is a pic of the cam buckle and hook loop. Strap from the bag doesn't touch the exhaust cover.
yamajohn
- Apr 25, 2006
- Sudbury,ON
- 2013 apex xtx
I have the trunk bag on my 13 xtx, there are 2 nylon sling hoops that get bolted or riveted between the tunnel and the hose cover on the side under the exhaust covers. the strap on the trunk bag when tight has 1/2" of clearance to the exhaust covers. Works well just keep it snugged up, lots of storage and comes off easy.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I
didn't notice those D rings in the bag with the cam buckles, as they were too close to the directions , which you cant look at before you install it ,only after ! And the Yamaha picture has the straps looped around the bumper , on a short track ,and it is the old style back end , with the wide exhausts !!!I have the trunk bag on my 13 xtx, there are 2 nylon sling hoops that get bolted or riveted between the tunnel and the hose cover on the side under the exhaust covers. the strap on the trunk bag when tight has 1/2" of clearance to the exhaust covers. Works well just keep it snugged up, lots of storage and comes off easy.
CaptCaper
- Jan 1, 2007
- Northern N.H.
They sell exhaust turnouts that work good so you can use a large bag on the platform.
Jonesynl
- Nov 6, 2014
- Roberts Arm, Newfoundland, Canada
- 2008 Apex MTX SE
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
They sell exhaust turnouts that work good so you can use a large bag on the platform. View attachment 106995 View attachment 106996
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Thanks for the pics.They sell exhaust turnouts that work good so you can use a large bag on the platform. View attachment 106995 View attachment 106996
I am looking to combine the trunk bag with some kind of gas container , for my sons sled that always runs out of gas , on the back tunnel extension .
I bought all the billet accessories , and somehow forgot to get the exhaust turnouts !
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
the second pic of the trunk bag , shows the straps looping around the rear bumper ??
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
if I hook it up likr that , the straps are right in the way of the exhaust on the new narrower exhaust models .the second pic of the trunk bag , shows the straps looping around the rear bumper ??
