06attaker
Bought a pair of tuner skis on black Friday special with 6" and 4" carbides. Also put the OFT relocator on at the same time. I have 144 studs in the center. HOLY SKI LIFT BATMAN!!! How can I tame this combination? Go 4" and 0"?? I have woody's now but do they sell just a plain bar for this ski??
Thanks for any help!!!!
Bluebullet
- Mar 19, 2005
- Massena NY
- Maine
I am running 4 center and 2 outside with 188 pics on my 2010 Apex LTX and have no ski lift? Did you have any with the stockers? Might need to check your ski alignment, toe and chasis set up? Most peoples sleds com down with the tunner skis?
Blue
Blue
06attaker
What's the best way to do this? Just put the oft on and didn't adjust anything. Looked straight to me but where should I measure from?
Cherry08
you can check out this thread has some good directions on how to set skis...
06attaker
Awesome!
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I would begin with less transfer from the rear. A ski biting hard is not a 'bad thing'
06attaker
My transfer is at the first hole. I was told to bring it down a hole and loosen the front spring by the straps...
old man winter
I cant speak for Yamadoo but I think he was referring to setting your transfer rods for less transfer. I wouldn't pull the strap down unless you are fairly heavy. you might want to add some preload to the center shock also if you are still at factory settings (a little at a time and then test)06attaker said:My transfer is at the first hole. I was told to bring it down a hole and loosen the front spring by the straps...
