polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Ted Jennety Clutching, jetting, air box mod.
Arctic Cat Z1 Turbo 128" Rear Suspension
128" Hacksaw 1" track.
Heated seat
Putting a set of Tuner skis on my friend's 05 RX1. When I did this on my 05 last year, the rubber pad under the spindal was too thick and they would not fit. The dealer told my friend that these would bolt right up. Any body else have experience with this?
Not sure if you tried this or not but set some weight on the ski until the bolt hole lines up then put the bolt in.
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Heated seat
If I remember right it was like 1/2 too thick. I thought I remember someone saying to use the rubber pads off of a apex . Idk
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Heated seat
skis installed
I put the Turner Skis on today on my friends sled. They were a direct bolt on, took mt about 15 mins.
I had C and A pros on my sled. I am wondering if the C and A required a different pad because they would not fit.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
With the Stock rubber pads from the Stock ski it's a Direct bolt on. I have the Tuners on my RX-1 turbo sled, Nice skis, steers good on the trail.
fast1200gp
rx rider....steers good? meaning easy steering? does it grab in the corners? or push? what rear suspension in rx1?,,just seems easy steering in rx1 means alot of ski lift or no ski grab,,,
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Steering effort is about average, I came from SlyDogs and the Tuners is more effort, but the Slydogs do not bite much. The Tuners have more bite and corners very well. I run a AD Boivin ZX-2 skid, and Fox Floats up front, I do not have ski lift unless I give it some throttle, 350 HP will make the skis lift LOL
fast1200gp
yea 350 will do that,,,,im running a 121 ripsaw 2 track m-10 air.fox float evol's up front,with deep keel yamaha ski's.....the tuners have my intrest,,,i tried the c a razors,,there were great under like 30mph but when u tried to come into a turn hard there was no grab...
