If I was to get a 05 Rx1 and out a stage 2 on it form bender how much hp will that make,can it be run on pump gas?what will the top speed be on it with a 200lb man on it?
Benders stage 2 comes set at 4lbs (180HP) and 8lbs (220HP). They recomend a race fuel mix on high boost. Their ratio is VERY conservative. There are many who have ran fairly high boost on pump gas.
BTW, those boost numbers can easily be increased by playing with the waste gate.
If you want more boost on pump fuel safely you will have to look towards a thicker gasket or LC pistons.
Ok can you pump up the boost by your self or how do you do it?I really want to beat my freinds sled he has a zr800 with a 900 kit in it.how is it on the trails is it too fast?
8 lbs will be MORE than enough to send your buddy home with hurt feelings.
As for how it is on the trail... I'm a mountian guy not a trail rider. Mine at 10 lbs is to much for me on the trails. 159's with 10 lbs of boost tend to push through the corners pretty bad. I just don't do the twistys very fast, that's why I have a switch for 5 lbs.
