Turbo installer somewhere in MN or northern WI
I ran the mcx 200 kit last year , 2011 eps apex.
Eric , the owner at MCX talked me into going to the 290 , reprogram , add head shim , add fuel pump .
Safer with the lower compression than the 200 kit with stock engine , on the same fuel !!
Could give you a real time report if we ever get Snow.
We can do installs, and offer engine and track dyno testing to confirm results. Jeff Simon / SIMONS CPR 1-414-698-6611 RICHFIELD WI
Hey Mr Simons, your just outside of Milwaukee, right? I went to school there. Do you do head shim installs and head studs? Something pump gas here and in the hills? Oh and how long would an install take? Could I drop it off and it be done in a day or two or three?
Thx much!
Mike
We are 20 minutes outside north side of Milwaukee in Richfield Wi. We can do anything you want done, head shim, low comp pistons, installs, tuning, etc. it would take around 2 days to complete install. Jeff 1-414-698-6611
