yammiebhy
i would like to know where i could get a turbo kit for a phazer, that runs on 91 octane gas.
Any help would be greatly appreciated!
07Nytro
- Dec 8, 2007
- Winnipeg, Mb
- None right now
did you even search??
yammiebhy
obviously, but the only thing i found was MCX press and Boondockers turbo, but both are discontinued. I found a couple others too bu you needed half race gas octane 91 gas to run it, os i was wondering if anyone else knew anymore turbos.
Leno
- Jan 18, 2010
- Lindenhurst Il
- 2008 phazer 151
1st please take a minute and fill out your profile. Site rules... and u can turn the boost down on those turbos and run strait pump gas through them. Your best bet would be to try to find a uses one and go from there. I am probley going to make my own turbo for the phazer this summer if i can find the right size turbo it self
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
yammiebhy said:obviously, but the only thing i found was MCX press and Boondockers turbo, but both are discontinued. I found a couple others too bu you needed half race gas octane 91 gas to run it, os i was wondering if anyone else knew anymore turbos.
MPI Supercharger out there too. Or are you set on having a turbo?
yammiebhy
can you run MPI supercharger with just 91 octane gas?
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
yammiebhy said:can you run MPI supercharger with just 91 octane gas?
I called MPI and they said its no problem, but your 91 octane will simply limit your boost pressure (without getting technical about it)
Call MPI they seemed very knowledgeable and good to talk to
sobfrogg
MPI's supercharger kit is nice. However as mentioned earlier running only pump gas will limit you with how much power you can make. MPI is agreat company as long as you do not run anything at sealevel. They had no help for a friend of mine.
Ted Jannetty at Turbo Addictions was a world of help. We would have never gotten the beast going.
My buddie ended up runing it on race fuel all the time and had the boost running at 10lbs. Why spend the money and not get all that you paid for.
