TURBO PHAZER
gsxr
BRACEBRIDGE , ONTARIO
Canada
2023 SRX
TURBO PHAZER MTN LITE , MCX(SWEEDEN ) HAS NO SNOW EITHER!
Leaving for Revelstoke 10 days , anyone have a clutch spring !!
YAMAHA PART # 905086001500 SECONDARY YELLOW
Only 40 miles on mine , NO SNOW , TOO TEST , HELP !!!
GLEN 705 645 2247
phone Vernon motorsports "yami dealer" in BC. Nick has been tuning a mcx phazer and might have what you need.
thanks , I will try him , called a number of other bc / alta dealers already !
FOUND A SPRING !! BEING SHIPPED TODAY ,
THANKS GUYS !!!!!!!!!!
What are you running for a primary spring? I was told to run a 90501-525J8-00. It pulls pretty good on top maybe a little low with 60 gram weights. I would like to increase the engagement RPM by about 500 to get rid of a little turbo lag. I was thinking about putting in a 90501-555J9-00 but I noticed that I can get the same specs out of the longer spring. Is there any advantage or disadvantage to the longer spring? By the way that secondary spring is the ticket.
JUST ADD 3 PRIMARY SPRING SHIMS
REVY BOUND TOMORROW AM !! NO SNOW HERE !!!
