POWERHAULIC
Re: turbo install
Yes, reverse fits fine w/stage 2 kit.
youngster66 said:Very nice pics. I am doing a bender stage 2 install. Seeing therse pics will help me with my install. My charge tube comes through between chaincase and radiator. Does anyone know if bender kit allows you to keep reverse? It looks possible but I don't have the linkage arms to do it.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
A few more pictures...
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
Looks good Allen. When will it see the snow?
- Apr 17, 2003
- Menno, SD
- Menno, SD
When it actually freakin snows! No snow in sight around here.
A
Anonymous
Look so much like when Iinstalled my bender, even charge tube, is looking exact same as bender's charge tube... only thing everything the other side
ken_climb
mulot30th said:Look so much like when Iinstalled my bender, even charge tube, is looking exact same as bender's charge tube... only thing everything the other side![]()
Trust me.....Its not a Bender!!
A
Anonymous
What difference?
Travis Moore
While you are at it, route the air filter out the back of the sled where the LH exhaust used to be. Looks great!
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Just curious Allen, how many miles were on this Apex before the install???
- Apr 17, 2003
- Menno, SD
- Menno, SD
It was brrand new 0 miles when delivered here. I put 30 miles of varied throttle and 5-6 idling heat cycles as well.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Still waiting for snow!
Forget the snow it's going on the track dyno tomorrow. I can't wait anymore!
Few more pictures...
BPE Gauge Pod & Gauges
Front View
Side View
Front View
Side View
- Apr 17, 2003
- Menno, SD
- Menno, SD
WOW is all I have to say. This thing is insane when on the boost! 143 hp to the track using Super Tips, different primary spring, Advant-Edge helix and stock secondary spring currently. Engages nice and low at 4000 rpm. Overall very happy with the MC Xpress system and I'm sure the customer will be as well.
snowy1
how much boost, with 143 hp. to the track.
- Apr 17, 2003
- Menno, SD
- Menno, SD
12 lbs currently. MC Xpress claimed 260 hp running exact as they suggest you to set it up.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Buttoned it completely up today. Very impressed with the MC Xpress kit, not as loud as I thought it would be and great HP. A slight amount of lag, but minimal and when it comes on I hope you have it pointed straight!
