rx1 fern
i finally took my turbo sled for a ride today after getting it back from from jim and bob manning at bpe performance known as lakercr.i couldnt believe how responsive it was .this sled rocks .i will never drive a stock sled again.turbo power is the best.the sled ran excellent with no problems at all .no leaks or anything and my air fuel gauge work good.the sled runs perfect.i am running 10 pounds for now and this is fun maybe i will turn it up and have even more fun.i would like to thank both of them for the excellent job they have done and for spending time getting it dialed in.the air fuel is perfect.the install on this sled is professionally done.thanks guys for the good job.we will do bussiness again .maybe low compression pistons and a bigger turbo next year.thanks.
Turk
Tech Advisor
Fern
Was my clutching OK? How were rpm,s? Front mounts have the same responsiveness as a stocker. Welcome to "club boost"!!!!!
rx1 fern
hi turk . the clutching works good .i was revving 10400 and it is engaging at around 2800 rpm.the sled pulls really hard .thanks for loaning me your roller secondary.i will let you try it out when you come to thompson .bring some riding gear buddy.i am having to much fun now.thanks turk for setting the clutches.
snoboner
- Sep 17, 2006
- Eagle Point OR
- MPI Viper
Which setup did you go with?
rx1 fern
powderlites turbo with hh clutch weights
Turk
Tech Advisor
Your gonna need a little more weight for 12 pounds boost & a w-w-w primary spring to get engagement a little higher. Will be up there in January.
SRXCAN
- Jan 31, 2004
Hey Fern, Blinky didn't blow up again? LOL, I seen you guy's out yesterday. was that you old 670 with you?
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
rx1 fern said:i finally took my turbo sled for a ride today after getting it back from from jim and bob manning at bpe performance known as lakercr.i couldnt believe how responsive it was .this sled rocks .i will never drive a stock sled again.turbo power is the best.the sled ran excellent with no problems at all .no leaks or anything and my air fuel gauge work good.the sled runs perfect.i am running 10 pounds for now and this is fun maybe i will turn it up and have even more fun.i would like to thank both of them for the excellent job they have done and for spending time getting it dialed in.the air fuel is perfect.the install on this sled is professionally done.thanks guys for the good job.we will do bussiness again .maybe low compression pistons and a bigger turbo next year.thanks.
Thanks Fern - glad to hear you're out enjoying it. Dave makes a well thought out kit, and it went together nicely. Now go buy some good gas and see what you really have under the hood!
Rx1M5
I haven't tried my turbo yet but and the sled already has Heavy Hitters. What did you use as a setup with the HH's?
I've got a front mount as well and will be in the 8-12 lb range to start?
Thx Rx1M5
Thx Rx1M5
Turk
Tech Advisor
PM me for hh set up with front mount at 10-12 pounds boost. set up a few of em now!
rx1 fern
yes that was my 670 with us .it was my girlfriend on it.she wasnt happy riding with blinky .she says blinky rides worse than a girl.she almost rearended him a few times .blinky is too slow on the trails.she rides better than him .we also seen you too bobby.your sled looks good when you drive by it.nice looking sled .sell it to blinky .i was also surprised blinky didnt blow up .he said he just redid his motor again .lots of people out yesterday.
