Turbo Vector vs Turbo Nytro
Vectorboost
Saratoga, Minnesota
06 vector mcx turbo
Headed to the U.P in a few days first chance at racing my friend with a 09 nytro turbo. he has a setup up that was originally on an rx1 home made plenum to except the 3 cyl vs 4 cyl . no innercooler, stock motor.rear mounted turbo, its a 144 with a 1 1/4 ripsaw no studs. stock clutching. running around 7ibs boost.
My sled is an 06 vector mcx turbo head shimmed and running 12ibs boost. extrovert drivers 2in challenger 136.. Running supertip weights dalton spring in primary and secondary and an H helix thru Ulmer.
When these sleds were stock i had the Ulmer clutch kit and a studded cobra track i could beat him out of the hole every time to 60 when he would come by. Hoping never to see him this time. Any thoughts
Yup,you wont now,12psi to 7 psi is a lot,on my turbo stock it was 10-11 and after the TD tune v-19 map 1 was 210 hp map 2 was 250 hp,now map 1 was 13-14 psi but map 2 was 16-17 psi was way more fun and hp,I think you will smoke him,and just for chuckles I now have an apex xtx 144x1.25 vrs another 136 attack,man I can walk him bad.
