ReX
One thing I find with my 05 RX-1 is I wouldn't mind a hint of extra ski pressure (with the stock skis).
But - how can it be done????
It looks to me like the front/rear weight balance built into the skid is fixed. There is no way (I have seen) to move any pivot point to adjust ski pressure. There is no front skid shock spring to loosen off, etc.
For WOT both the front limiter strap and transfer rod can be used, but there doesn't seem to be a way to adjust ski pressure while cruising.
I thought about tweaking the ski pre-load, but that will also lower/raise the front and I want to independantly adjust height.
Another question I have is - what good is the front limiter strap on these? Has anyone played with the balance between front limiter and transfer rod settings? I'm wondering if the two will affect the transition points (amount of throttle) to good weight transfer.
