basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
For those of you who painted your seats with vinyl spray paint how did it hold up throughout the season?
rough rider
seat
I painted my seat on my xtx in 2009 held up perfect so far for 2 seasons, I changed the grey part to red, I prepped seat and then painted it when it was 90 degrees out , set seat out in sun between coats I didnt think it would hold up ,but so far so good I used the SEM vinyl paint
phatkid
I used the dupicolor setup mine was blue and black
I have a little blue showing up in the front where i am always rubbing on while sitting needs a 2 min touch up job and will look perfect again
much cheaper than a 200.00 seat imo....
Jammie
Jammie
I have never had paint where off when using sem brand vinal dye, but they where out of it. So I bought the same as above duplicolor paint and it wears off. I will be stick ing with the sem brand from now on.
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
Re: seat
What did you prep it with?rough rider said:I painted my seat on my xtx in 2009 held up perfect so far for 2 seasons, I changed the grey part to red, I prepped seat and then painted it when it was 90 degrees out , set seat out in sun between coats I didnt think it would hold up ,but so far so good I used the SEM vinyl paint
phatkid
sem has a spray on vinyl prep that you shoot itt with first then spray the light coats of paint
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
sem???? What does that mean
Zipperno
- Mar 4, 2008
SEM is the brand name of the vinal dye paint.
Don't use duplicolor.
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
Well i just ordered my prep and paint. I plan on painting the gray part of my seat white. Its going to look sweet!!!!
stephenpen
Mine did not last very long. I even cleaned the seat with alcohol before spraying. After 2-3 rides you could see the blue coming through. It looked great as long as you dont sit on it
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
What did you use for paint
stephenpen
Dupli-color vinyl and fabric
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
O well this SEM stuff sounds like it works and for the price it better!!
stephenpen
Some guys have had really good luck
I did not prime mine with anything. Maybe that's were I went wrong
