Turbor
- Apr 16, 2008
- mirabel,quebec,canada
- sidewinder
the 09 chaincase has an extra bearing in the cover for the lower gear, what do i need to upgrade my 06 chaincase to these specs? cover, bearing and?
Turbor
- Apr 16, 2008
- sidewinder
nobody has taken a 09 chaincase apart to compare?
LazyBastard
Interesting. I wonder why they would put that there? To my knowledge, there has never been any durability problem associated with the chaincase bearings....
The answer to your question is; why bother? You would need the chaincase cover, bearing, clip, and the reverse gear spring retainer. Honestly though, I can't see this change actually doing ANYTHING AT ALL.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
Not bearing durability
But shaft durabilty... less SIDELOAD and potential flex on the drive shaft. especially on boosted sleds.
I think this is a good upgrade for high boost guys.
But will be an expensive one.
apltx08
They changed in '08 so if you can find a totalled '08 you could probably get a good deal on 1...good luck.
LazyBastard
Not according to the parts catalog....
And it isn't going to help with driveshaft flex -- the part in contact with the bearing is an aluminum extension to the driveshaft. If anything, this might be just for cover alignment.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
LazyBastard said:Not according to the parts catalog....
I do have a 2009 apex ltx gt.. and when I opened the chaincase... this thing is tight enough on the shaft to prevent shaft flexing... I am pretty confident on that one.
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
My friend's CPR race sled has a longer drive shaft with a bearing mount welded in to the outer cover of the case for shaft support on both side's of the drive gear. Evidently the shaft failure's after a fair number of mile's has made Yamaha feel they needed more support. They are looking for long term durability.
kviper
kviper
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
I am thinking about doing the upgrade.
kviper
- Nov 7, 2003
- Oakfield WI
By the way, Where are you getting the info of this change? I have not seen or heard anything of it till now. kviper
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
I do have a 2009 apex and I have seen all this stuff while opening the chaincase for maintenance.
I found it would be a good idea to upgrade my older 2003 rx1 with this... among a few other things
kviper
- Nov 7, 2003
- Oakfield WI
Interesting and a good idea! kviper
