Upper mount on front shocks????
black knight
ottawa ont. canada
I just put my gytr shocks back on my sled. The manual says 35lb
on the top nut and bold.
When I took them off they where snug at best. 2 questions
#1 If i torque them to 35lbs will i cause damage to the aluminum area that the bolt and nut go threw?
# 2 Should there be any slop in between the washer and the shock eylet?should it be tight?
Kind of 3 questions
07 apex gt
35 lbs is what is called for. There will be some slop in the mount. Tolerances don't seem to be that close on these things. Their all different and everything needs to line up at the factory.
