CANAM 4 Stroker
- Oct 26, 2005
- www.klim.com
- 2009 Yamaha Apex GT
Does anyone have a recommendation for the set-up of the USI Triple Threats on an Apex. Mounting hole location, stage of fins installed, and what carbine style and length.
I am on my 3rd season and have failed to consider my set-up "dialed in". Any advice would be appreaciated. Thanks
Check the ski section theres plenty of post on setups.
LJ 452
Need to know what you are looking for, riding style, type, etc.
CANAM 4 Stroker
- Oct 26, 2005
- www.klim.com
Groomed trail. Hard pack agressive riding. Minimizing darting is prefered
the kitchen
I have run mine for three years now and have stuck with the stage two front and rear with 6" duce boy carbides and run the spindle in the middle hole. You do not need the duce carbides because they do not dart but will chase a bit at slow speeds, the duces eliminate at all speeds. I ran the power steering plates for two years and they do help the effort a bit but your carbides will wear mostly in the center. To keep them planted in the corners I take most of the transfer out but not all as you would spin too much. I keep more pressure on the front springs to minimize body roll and ski lift. I know this will raise the front end a bit but find it works better than lowering with soft spring set up. I also set the pre-tension on the rear shock to max as I am 6'1" 215lbs. You will never miss a corner!! This works for me.
The only change I would like to make is to lower the front end to flat but keep tight springs, not sure how to do this yet.
LJ 452
the kitchen said:I have run mine for three years now and have stuck with the stage two front and rear with 6" duce boy carbides and run the spindle in the middle hole. You do not need the duce carbides because they do not dart but will chase a bit at slow speeds, the duces eliminate at all speeds. I ran the power steering plates for two years and they do help the effort a bit but your carbides will wear mostly in the center. To keep them planted in the corners I take most of the transfer out but not all as you would spin too much. I keep more pressure on the front springs to minimize body roll and ski lift. I know this will raise the front end a bit but find it works better than lowering with soft spring set up. I also set the pre-tension on the rear shock to max as I am 6'1" 215lbs. You will never miss a corner!! This works for me.
Pretty much it.
They will steer a bit harder but that's the nature of an aggressive ski. I didn't use the power steering plates because I preferred the more positive steering. For what you ride I would think using them would be fine. Adjusting the mounting makes a huge difference in effort and bite. Remember to check your toe adjustment as well, not sure what is recommended by USI but I would think 3/8" to 1/2" toe out would work. Remember you've got the front strap on the rear suspension to play with as well.
