grossman
Any reason to not treat each tank of gas with some Sea Foam or other comparable additive? Seem's like it would be a good idea to help keep the carbs clean and stabilize the gas. At least for me I might ride the sled every day for a week then it might sit for another 2-3 weeks.
Thoughts?
Thoughts?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
It should be fine, I only use it for the first and last tank.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
APEX 06 said:It should be fine, I only use it for the first and last tank.
X2 but I also use it periodically during the season as well(2-3 times)
I also see no harm but imo, it is not that necessary if your sled is only sitting for 2-3 weeks max?
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
if you want to use some to help use yamaha Ring Free every tank
Paraclete
Irv said:APEX 06 said:It should be fine, I only use it for the first and last tank.
X2 same here
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
darv said:if you want to use some to help use yamaha Ring Free every tank
x2
Yooper_Bob
I put stabil in every snowmobile/motorbike/boat/lawnmower/snowblower I have, EVERY time I fill up.
It never fails, I think I will be using it shortly, and then the weather changes (or the wife kills my plans), and fuel ends up sitting for a month.
