Valve cover Gasket Leak
stephenpen
Barrie
Has anyone ever had a valve cover gasket leak. I'm leaking oil out the side where the little half circle (cam seal ?) is. There is a 2 little tears and it looks as if the cam seal was pushed out.
Sounds like you may have got your crank vent tube iced up at some point. Crank pressure would have popped this out if this happened.
I never thought of that. I was thinking worse case.
Thanks. I feel better now
