RADNYTROFX
looking to add a riser to a vector. does anyone know how big you can go with a riser without having to lengthen any cables? i hear 2 is safe, but how about a 3-4 inch riser?
thanks
thanks
Yeller
I added a 2" to my nytro. I would say that a 3" could be added without extensions but a 4" may be to tall ... that's just a guess based on my experience.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
What year Vector? If is an 07 or older I would say 2" would be max. And that is will a pivot riser rotated forward. I have a ROX 2" pivot riser on my 07 Rage and I do not see how you can go any taller. You will have to un-clip the parking brake cable when install a riser. G.B.
DaJudge
- Nov 29, 2005
- West Michigan
- '06 Rage
I put a articulating 3 1/2 inch Rox on my '06 Rage. All I had to do was reroute the parking brake cable.
I put a 4" mountain machines pivot riser from Rich Motorsports on my 05 vector with no issues I rerouted the cables.
Any other brand you can not run 4", mountain machines pivot right at the base bringing the bars forward giving you more slack as such as a roc or other brands.
Rich is very informative about risers because he deals just about every brand.
sleddheadd
i am adding a 2" riser from rich motorsports to my wifes sled this year. if we add the riser and hand guards will we be able to keep the stock windshield? or will we need to shorten it up?
