Vector- Warning Light
kendoo
New York
What are some reasons the warning light (yellow triangle) would come on? It's on, not flashing. Nothing felt wrong with the sled. Thought initially it was high temp light because I was putting around with my son and not kicking up much snow to cool things off. But I checked the owners manual and it looks like there is another indicator light for high coolant temp. Any ideas on what to check?
After reading the manual closer, it looks like the warning light does come on when overheating. I didn't look close enough to see what other lights were on at the same time.
This light will also come on when low on gas,Its to get you to look at the gas gauge, If its hot the heat light will come on also.
