Vector warning indicator question +
nealchick
Long Island, NY
Website
www.briarclifflandscape.com
I've had a recent issue on my '05 Vector, barely ridden 30 miles, the warning light comes on looks like a triangle, no other message or code is given, and the motor wants to stall or cut off momentarily. Then it will run fine for a few minutes and repeat.
Any input would be greatly appreciated. :o|
Maybe you need to adjust TORS. (i.e. throttle cable free-play)
Do you have an Operator Manual? Adjusting TORS, as well as a lot of other good info about the warning indicator and how to interpret it, is in there.
Could be wire chaffing.. it causes lots of problems.. hard to find sometime
check in nose where main cable goes down around storage box.. below handle bars.. along side of frame on chaincase side...
