- Nov 29, 2009
- sabattus, maine
Tried a search but didn't come up with anything. friend of mine has I believe an 11 Venture and it keeps blowing the fuel pump fuse. put in a new one will run a few and blow again. Any ideas where to start looking?
might have a bad relay for my 1st suggestion. if it is getting hot it is bad. test by swaping in a new relay or a different one.
next I would ohm test the wires to the fuel pump and check for a rub through.
last thing I would look at is the fuel pump. I have had one that would heat up and quit on my truck if I did not have enough gas in the tank to keep it submereged. my 08 wr250x did this to me this summer as well.
- Nov 29, 2009
- sabattus, maine
turned out the fuel pump was toast. He traded it in for a 13 Vector
