Video replacing hyfax nytro using reverse
SIKEWARD
Rockford, IL
http://www.youtube.com/watch?v=L5s9huklRu8
Here is a how to video I made when changing my hyfax using the reverse method. Go easy on me guys. I'm no George Clooney. If there is something I missed let me know so that I may try to edit it. As far as the sound goes I have no idea why it is off. I used windows movie maker. If someones knows how to correct it let me knnow.
I always was curious how the reverse method worked. Good video! Im definately going to give that a try next time i change the hyfax :Rockon:
That's a helpful video...Thanks...One question...what was the lubricant you used on the new Hyfax before sliding it into place?
I used jigalube. I picked that because it will dry and not collect dirt over time. I also sprayed that on the track window.
I havent tried this yet but a dealer told me the easyest way to remove hyfax is to remove retaining bolt and them just slide a large flat screwdriver through a track window and between ths slide and the rail at the rear . The screw driver will feed the slide out the window when you put it in reverse. Anyone try this?
That is how I do it. Just go slow you don't want to send the screw driver into the front cooler.
