802 Rider
- Dec 30, 2016
- Vermont
- 17 Sidewinder LT-X SE, Turbo Dynamics Power Trail Tune 270hp, Turbo Force Muffler, Dalton Clutch Kit, SLP Powder Pro Skis, 144 Woodys Studs
15 SR viper XTX
12 FX Nytro XTX, MBRP Trail Exhaust, Barcode 365 Upgrade Front suspension, C&A RZ Trails skis
08 Fx Nytro RTX, MBRP Trail Exhaust.
05 RS Vector ER, Hauck Exhuast & Clutch springs.
05 RX-1 ER Limited
03 RX-1 ER
02 SX Viper ER
01 SXR 700
97 SX 700
92 Phazer II
89 PHAZER
81 SS 440
82 Bravo
- Vermont
I started a track swap on a 15 Viper XTX today. On the tensioner bolt, did yours have a space between the bolt its self and the roller bracket that the spring you mentioned? Is the spring supposed to hold the roller bracket away and off from the tensioner bolt? Im trying to add a photo but it will not upload
802 Rider
- Dec 30, 2016
- Vermont
15 SR viper XTX
05 RX-1 ER Limited
03 RX-1 ER
02 SX Viper ER
01 SXR 700
97 SX 700
92 Phazer II
89 PHAZER
81 SS 440
82 Bravo
- Vermont
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I don't recall but I believe it's normal, it should come in contact when the sled is moving, that's when the slack side of the chain pushes against the tensioner thus keeping proper chain tension, remember finger tight and 1 1/2 turns out and tighten the jamb nut.I started a track swap on a 15 Viper XTX today. On the tensioner bolt, did yours have a space between the bolt its self and the roller bracket that the spring you mentioned? Is the spring supposed to hold the roller bracket away and off from the tensioner bolt? Im trying to add a photo but it will not upload
Clamb
- Oct 2, 2016
- Peoria IL
- 02 Sx viper Er 15 sr viper xtx
- Peoria il
I just finished a track swap on my 15xtx and yes the bolt was not touching the tensioner when set at 1-1/2 turns out on mineHere we go. This photo
