VIPER LTX SE
well I hope mine gets faster.looks like the belt is not getting to the top of the clutch. going to put a line on clutch with a marker and see how hi the belt is getting
I put shims in my secodary to raise it up also. Still not where it should be even with a new belt. I wonder why?
Putting in shims or washers on your secondary will not give you top end. Just give you a better hole shot. Need to get the primary to pull belt to the top of the sheaves. I have an old speed sheave I Had on my 2002 Viper on my primary. Wonder if I should try that to get it to shift to overdrive.
How are some seeing 100-110 mph stock & some not seeing 100 mark?
Yamaha clutching is usually pretty consistent...
75-100 lbs difference in riders weight???
350 miles on my LTX 137. Best ive seen is 91 on the speedo. This was maybe a 3/8" mile groomed trail. Not sure it would have changed much if I held it for a mile.
Similar results with my 09 Nytro fx 121. I never saw a 100 on that thing but others with longer tracks were posting higher speeds.
I also dont get in the habit of believing everything I read on the internet. When I see a stock Viper hitting over a 105....Ill believe it then.
