yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
has any one tried running vp u4.4 in their machine? Got a can here and looking to mix it 50/50 just looking to see if any one has run it in the past
Thanks guys!
Thanks guys!
wot-75
Thanks guys!
Basically a waste if you're not tuned for it... even more so if you mix it with regular fuel. Just my 2 cents.
I'd like to ride behind you for the smell though
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Why do you say it's a waste?
Because to take advantage of it you need to make the mixture richer.
If I remember right C12 or even Turbo blue with advanced ignition tune put same power out.
Try MR9. Be prepared to drain tank and flush with gas though.
tapex_07
- Feb 15, 2009
It's not like he'll make more power, but it will be safer. I personally will be be running race fuel in my Nytro and a mix in my Viper for cheap insurance.
wot-75
U4.4 is a direct replacement fuel.. not designed for "mixing". To best optimize any race fuel you need to get a custom map made for your motor using the race gas of your choice. Then, using for instance a PCV, get a map toggle switch so that you can switch between pump and race gas maps on the fly.Why do you say it's a waste?
Just pouring it in or diluting with regular fuel will give you no real noticeable gains. At $16-$18 a gallon I would do it right otherwise, imo, it's a "waste".
There are real measurable gains to be had with race gas and proper tune to better harness it's inherent properties, but prior to that you're just wasting your money IMO.
tapex_07
- Feb 15, 2009
I didn't know the U4.4 fuel was a direct replacement fuel. I was thinking more along the lines of adding for octane (due to how we all get watered down gas sometimes).
yukon yamaha
- Jan 30, 2008
Thanks for all the info , I did build a map just for U4.4 and full tanks. I was thinking about 50/50 just to ensure better chances at a good octane number.
I guess I will have to try both and see how it works.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Be careful with leaded fuel it is hard on your o2 sensor. U4.4 has lead..
