Boomer
This just showed up on eBay
http://cgi.ebay.com/ebaymotors/Lightwei ... 1399QQrdZ1
Excuse my ignorance. I was wondering if this is the same part as the W-Arm.
Also does anybody make an aftermarket W-Arm that will not break like the beloved W-Arm.
I've looked everywhere on here but can't seem to find any.
LazyBastard
Not quite. They are the same part, but for different skids. The H-arm is for MOUNTAIN skids, whereas the W-arm is for shorties.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
That looks like an aftermarket arm. It's possible that the manufacturer chose the H-arm design to utilize 2 stronger, H.D. arms instead of the weaker, OEM W-config? Maybe they will tell you who made it, and the model#?
I would definitely verify this, and ask for a written, money-back, gaurantee that it will work for the RX-1 shorty, before you bid. Otherwise, you will send a NASTY feedback report if it doesn't work.
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
LB is right, this is a H-arm for the mtn Pro=Action skid. I'm curious who the aftermarket company is that made this version. The one's I have seen all usr round Chr-Moly tubing for their designs. This is allmost identical to my stock Yamaha. Only difference in apperance is the two grease zerks at the end vs one in the middlle on my stocker and, the lack of gussets on the cross bar of the "H".
Jim
Jim
We developed a H arm from hardened aluminum a while back and it is for the shorties or mountains. We made it to be stronger and save weight. It saves over 6 pounds. The stock W arm weighs 8.25 pounds and our H arm weights 2.2 pounds.
LazyBastard
How the hell can an H arm work on a shorty? The reason its a W shape is because the rails have to pass through it.
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
That and the shorty rails have no place to mount the front shaft for the limiters. Maxdlx
I will try to get pictures of it installed shortly.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
LazyBastard said:How the hell can an H arm work on a shorty? The reason its a W shape is because the rails have to pass through it.
LB, you can either work with the existing design, or you can redesign it altogether.
Maybe I'm wrong? But no one else used a W-arm design, and no one else had as much trouble with failing torque arms either.
LazyBastard
The cause of the failures was in the position of the limiter straps - very close to the pivot, which caused excessive stress on the W-arm at the point where the strap crossed, not with the shape... fact is that the W is actually a better shape from a structural perspective.
