green
- Oct 5, 2009
I bought a ProArmor tether kill switch (the T handle style) for my Yamaha Apex MXT 07 and my problem is that after I disconnected the stock kill switch and routed the new kill switch wires through the tether it only works when the tether is pulled not with the tether still attached like the way my old switch worked. I want it to work with the tether still attached.
There are no instructions, called the manufacturer, who said they don't design them for snowmobiles and that they run the through the stater, not where I have it installed. I think when the tether is attached it creates an open circuit and when the tether is pulled it forms a closed circuit, correct?
I haven't installed a switch like this before - has someone done this in the same way that I've described that I'd like to keep it, or can it be installed through the stater (or whereever)?
TIA
TIA
mysledblows
- Jan 23, 2007
- Central MN
- Sidewinder, mcx phazer, phazer, apex
- Jenkins, MN
You need a normally closed and have a normally open.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
mysledblows said:You need a normally closed and have a normally open.
X2
