warning indicator on
woodchk454
Niles MI
my warning indicator and warning light are flashing in what appears to be pattern #3 from page 5-9 in the owners manual 2 short bursts and then repeat. I just finished a bunch of maintenece (overdue) and some upgrades including apex bars and warmers and have yet to wire up the heaters (not sure how just yet i know in parallel but not what it means) is this the culprit or should I be concerned about something else as the book shows the pattern but not what it is. Thanks again to the TTY Techs you guys are life savers.
jim
Two bursts should be the Grip Warmers. Once you have them wired corrctly, the signal you are seeing should clear.
