sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
I am I wrong to think if there was bad idlers or bearings/locked up parts in my 08 skid that it should be covered under my extended warranty, or is that considered wear and tear?
Len Todd
They replaced my rear wheels under YES. The problem was the bearings going bad and they were the ones that are molded in the wheel. If you have wheels with replaceable bearings, I suspect they will replace the wheel if it is bad. But if you have replaceable bearings and the wheel is good but the bearing is bad, then I would suspect they would want you to cover the cost of the bearings. They are cheap and easy to change.
This is one of those times when your "partner to having fun" is your Service Manager.
