I have an 04 warrior, I am bottoming out when I hit the dips. I believe I need the big boy spring I see mentioned on here allot. Does anybody have the part # or suggestions for a rear shock upgrade? Thanks.
Yooper_Bob
I don't have the part #, but I had the same issue...put in the new spring, and now I am able to run the rear suspension settings in the middle, instead of having everything maxed out.
BTW, I run about 270# before adding gear!
Definitely well worth the time and $$.
Sounds like exactly what I need, I'm about the same weight. Any chance you can find your reciept? or does anybody else know the part# Thanks
Yooper_Bob
I know I don't have the receipt any longer....at the same time I had the spring put in, I also had the sled extended to 151" along with an new track and extrovert drivers....I burned the receipt so 'da wife wouldn't see how much I spent!
